Browse Forums Renovation + Home Improvement 1 Aug 25, 2016 1:21 pm Hi Renovators, My house has external attached toilet. It has approx 5 sq m roof (no menwhole). Slope might be 5 degree. When there is heavy rain with wind, water comes inside the toilet. So, plan to replace Terracotta tile with some other solution. I am thinking of one of the two things. Need your opinion and any other alternative. 1) Put plywood and attach shingles 2) Colorbond Roof. What do you think? -GC Re: External Toilet Roof (5 sq m) 2Aug 25, 2016 11:57 pm gobarchand Hi Renovators, My house has external attached toilet. It has approx 5 sq m roof (no menwhole). Slope might be 5 degree. When there is heavy rain with wind, water comes inside the toilet. So, plan to replace Terracotta tile with some other solution. I am thinking of one of the two things. Need your opinion and any other alternative. 1) Put plywood and attach shingles 2) Colorbond Roof. What do you think? -GC A sheet metal roof like corrugated Colorbond shouldn't be laid at less than 5º although I wouldn't lay them at less than 7º to be safe.A tiled roof shouldn't be less than 15º. I wouldn't be using shingles at that slope either. Kliplok may be a better option unless you can improve the pitch by using bigger battens at the high end of your roof. Stewie Re: External Toilet Roof (5 sq m) 3Sep 06, 2016 12:44 am Stewie D gobarchand Hi Renovators, My house has external attached toilet. It has approx 5 sq m roof (no menwhole). Slope might be 5 degree. When there is heavy rain with wind, water comes inside the toilet. So, plan to replace Terracotta tile with some other solution. I am thinking of one of the two things. Need your opinion and any other alternative. 1) Put plywood and attach shingles 2) Colorbond Roof. What do you think? -GC A sheet metal roof like corrugated Colorbond shouldn't be laid at less than 5º although I wouldn't lay them at less than 7º to be safe.A tiled roof shouldn't be less than 15º. I wouldn't be using shingles at that slope either. Kliplok may be a better option unless you can improve the pitch by using bigger battens at the high end of your roof. Stewie i never thought that a tile roof shouldn't be less than 15*. that is something that should be remembered as well as the other information that you shared. i hope i will be able to fix on ours too. thanks alot! Looking at some of the designs on websites, they are all selling very similar products. I get that you want something stylish. It's worth looking for search terms like SaveH2O… 2 4600 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 3000 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 37 14040 |
