Browse Forums Renovation + Home Improvement 1 Aug 01, 2016 6:38 am I am looking to extend 200 x 50 hardwood floor joists, they span 3.6 meters at 450mm centres. I want to extend them to cantilever 1.2 meters past the existing wall. What length of overlap do I require, and method of fixing, if I am using the same material to extend the joists. Any advice would be appreciated, Thanks Re: Extending Floor Joists 2Aug 01, 2016 9:07 am Hi L300 Welcome to the forum Things that need further consideration 1. Is this a balcony internal or external? 2. Is the wall sufficient to take extra loading 3. Additional loads for posts/columns etc 4. Deflection for hogging, floor finishes & tensile cracking? Councils also require Structural Plans otherwise its an illegal structure As you can see more info ,photos, sketches are required Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Extending Floor Joists 4Aug 01, 2016 9:46 am Your welcome, I try not to discourage people from posting photos & asking general structural questions ..but it(balconies) will need to be examined/sighted and signed off by an Engineer Better still see if you can find an engineer that also does all the work( if you are not inclined to?) on such small projects the drawings and certification are usually thrown in. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14607 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 16796 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5811 |
