Browse Forums Renovation + Home Improvement 1 Jul 17, 2016 10:36 am Hi, I'm looking at buying my first home and the place I'm looking at has been relocated to where it sits now. My question is is there any problems that can arise while renovating (knocking walls down, extending boundaries of the house, raising the house, etc.) due to the house been previously split, relocated then joined back together? Thanks in advance. Re: Question about renovations on relocated houses. 2Jul 19, 2016 1:04 pm It will depend largely on who did the original work of moving it ( a fairly large proportion of these guys sound like cowboys ). You should have a comprehensive report from both a building inspector and a structural engineer done. Stewie Re: Question about renovations on relocated houses. 3Jul 22, 2016 7:24 pm Once moved an put back together they are like any other house. You will be able to find any problems with a building inspection. We have lived in relocated houses and they have all been renovated successfully. No different o any other house You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9958 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6150 1 13121 |
