Browse Forums Renovation + Home Improvement 1 Jul 11, 2016 2:17 am Re: Hole in the wall, weird wall filling 2Jul 11, 2016 7:27 am It looks like the previous homeowner has blocked up a doorway or some sort of recess in the wall. Best way to fix it is to remove all the infill bricks ( all the grey coloured area ) plus the rusting steel lintel and to tooth into the existing bricks and re-lay them. Stewie I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36937 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4461 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31280 |
