Browse Forums Renovation + Home Improvement 1 Jun 26, 2016 9:17 am Hi all. We had our house acrylic rendered yesterday in melbourne. Its cold cold weather so i dont know if this has anything to do with it. So they did two coats of render now this morning i have woken to this..... is this going to stay like this with the bricks showing through? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Render job - Help!!!! 2Jun 26, 2016 10:38 am It should dry completely in a few days. The outline of the bricks you see is where the existing mortar has sucked up more of the moisture in the render and when it dries out should disappear. Stewie Re: Render job - Help!!!! 3Jul 04, 2016 8:31 am That'll dry out for sure. But its melbourne, so it could take a little longer than your northern neighbours. Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7043 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10412 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 11562 |
