Browse Forums Renovation + Home Improvement 1 Apr 20, 2016 7:33 pm Hi everyone I have searched around for answers on this topic but not found anything as yet, so hopefully this hasn’t been covered under a different thread already.
With the $11000 cap on trades doing work in a renovation on Qld (*when not using a builder or going under owner builder), can anyone tell me if these would be ways to get around it. A.) In a bathroom reno where you might need plumbing, tiling/waterproofing, shower Glass etc. Assuming you could get each trade to do their bit for under $3300 and in total the work and materials came under the $11000 threshold, would this would be ok legally with no need to use a builder? B.) Could you also get around the $11000 rule if it was possible to get low enough quotes from trades but do most of the work yourself instead and only use/pay for work you have to such as plumbing (an occupational licenced trade)? I know trades are pretty expensive per hour wise but if you had mates or found a trade that would quote low for jobs just so you could stay under the $11000, couldn’t these be the quotes you went by when estimating the cost for the total job (whose to say their price is too cheap;) Also does anyone know if there is a time frame that $11000 cap would stand. For example could you do $11000 of work each month and have a short break or every 6 months, or yearly? Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 5311 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4381 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7181 |
