Browse Forums Renovation + Home Improvement Re: Facade reno, rendering, facelift etc. 4Apr 15, 2016 6:39 am I think it would be worth getting an architect to do a few concept sketches for you, then get a few builders to quote on it. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4897 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5240 |
