Browse Forums Renovation + Home Improvement 1 Mar 15, 2016 5:20 pm Hi, I've got a 7200x3400 metal sheet roof carport (skillion)where I want to remove half of the roof - 3600x3400. I'd like to maintain the other half to later close it in from the weather. I'm wondering if I remove the metal sheets back to where I want (where, conveniently, there happens to be rafter in line with where I want the new end) and the battens are cut away, can I simply put new fascia boards up and place new flashing along the new open edge? Am I correct that the framework (rafter/batten) underneath wont need reinforcing? Or will the new end rafter need altering? The carport is a stand alone skillion, so only one pitch to worry about, and no extra guttering is intended. Any ideas appreciated - better yet, a how-to guide for dummies Cheers, Shani. Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20577 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 753 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6900 |
