Browse Forums Renovation + Home Improvement Re: cost for total renovation 4Mar 13, 2016 8:21 am Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: cost for total renovation 6Mar 20, 2016 1:51 pm chode1984 Sounds like it would be easier to knock down and buy a house to have moved onto the block. Not sure how common that is in Victoria but it's fairly common up here in QLD. Thanks for your response. Also considered that option too. Is possible in Vic (Golden Age Homes, Moving Views, etc), but by the time you do that with cost of removal, connections, trying to find a bank that will lend on it before finalised (occupancy certificate), council guarantee fee, would imagine it will be in ballpark of a new build with a project builder? Going off on a tangent here, anyone know lenders for removal homes in Vic that will finance? Thanks NOH Re: cost for total renovation 7Mar 20, 2016 4:13 pm chode1984 Sounds like it would be easier to knock down and buy a house to have moved onto the block. Not sure how common that is in Victoria but it's fairly common up here in QLD. It's probably less common down south because of the way their homes are constructed (brick). By contrast it's pretty easy to shift a Queenslander - basically a big timber box on stumps... Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: cost for total renovation 8Apr 12, 2016 11:45 pm No one can help you without seeing it themselves. I'd say your estimates of cost are quite reasonable. Is the frame of the house really worth it? Re: cost for total renovation 9Sep 02, 2016 8:57 am ONH, try this quick and easy renovation cost calculator http://www.homeone.com.au/articles/bathroom/online_renovation_cost_calculator Good luck. Richard@themakeovergroup Re: cost for total renovation 10Sep 06, 2016 2:10 pm Need about $15 k for a new bathroom but mabe get away with 10 for a small one. Kitchen at least $15k Re: cost for total renovation 11Oct 21, 2016 8:25 am My question would be what is the purpose of the property? Rental or PPOR? If it's rental, in a regional area, are you going to add $100k to the value of the property if you spend it? If not, you're in overcapitalisation territory. We also have a property in regional Vic, purchased for $73k a few years back. We recently spent ~$6k on carpet, lino, paint etc and increased the rent from $145 or $150 to $180 per week, but anything more in terms of spend and the rent increase would be a case of diminishing returns. We still have a couple of other things to do, but we'll top out at about 10k I think. I wouldn't think about spending 100k on a 100k property in regional vic. You just won't get the return. Re: cost for total renovation 12Dec 12, 2016 9:27 am I agree your costs are too low, are you doing the work yourself? Restump, not enough info and i have only done raises, but this seems low. deck $10k - what about a cover on the deck and/or a garage? no roof/fence costs. Bath will definetly be a bit more than $6k. I dont see any floor costs. Re: cost for total renovation 13Oct 17, 2017 3:03 pm Hi Newoldhouse, You might want to try this renovation costs calculatorto help you. Regards Richard@themakeovergroup Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5466 Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3484 Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4785 |
