Browse Forums Renovation + Home Improvement 1 Feb 08, 2016 8:48 am How difficult will it be to get a DA approved to put on an additional floor making it total of 2.5 stories? (Warringah council in Sydney) Our current house has 1.5 levels. Ground floor garage is 0.5 and the first floor is 1 level. The land slopes from left to right. Example house to avoid confusion of my wording: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I know that council DAs have a 2 story restriction and a garage is considered a story (at least for that half of the house). Won't be able to use CDC because they are strict on 2 stories. There is also a 8.5 metre height limit which we can satisfy by having a flat colourbond roof. The other option is for us to make half the addition as a open roof top terrace. Perhaps this satisfies the 2 story restriction? Re: Council approval for 2.5 story addtion 2Feb 08, 2016 12:00 pm You should be able to do what you want to do despite the two storey limit. Warringah Council will give you a certain amount of latitude under Clause 20 because of your sloping block and your garage is also not a habitable space. As long as you comply with side boundary envelopes ( 4m high at the boundary and 45º ) and your side and front setbacks ( 900mm and 6500mm ) you should be fine. Most DA's with WC now take around 45 days unless there are issues with any of the above, neighbours objections etc I'm sure if have a good look around your area you would find examples of other properties where the owners have done similar especially in some of the hillier suburbs like Freshwater ( where we are ) or Allambie Hts, Beacon Hill etc. Stewie Re: Council approval for 2.5 story addtion 3Feb 08, 2016 4:46 pm Thanks for the quick response! I was looking at the DCP for Warringah council and saw this in "B2 Number of Storey": To measure the height in storeys : The number of storeys of the building are those storeys which may be intersected by the same vertical line, not being a line which passes through any wall of the building; and Storeys that are used for the purposes of garages, workshops, store rooms, foundation spaces or the like, that do not project, at any point, more than 1 metre above ground level (existing) are not counted. When it refers to "Ground Level", is this the level of the living area? If so, then this will allow for Garages/Basements which are built underground or at least 1.2m below the living floor (assuming basements and garages require 2.2m heights) Re: Council approval for 2.5 story addtion 4Feb 08, 2016 6:26 pm Another quick way of finding out is to take a couple of pictures of your place from the street and then go down to the council chambers in Dee Why and ask to see one of the duty planners. They will be able to tell you pretty quickly. How far above existing ground level at the side does your garage project to the garages ceiling level ? Stewie Hi Minho I have heaps of experience in Ku-ring-gai with both DAs and CDC ( this is the main area we build in). DA's are taking 12-18months and CDC's we have been doing… 1 3165 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8482 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4090 |
