Browse Forums Renovation + Home Improvement 1 Feb 04, 2016 1:47 pm Hi, We currently have a 3bd 1 bath 1960's house which we are planning on extending - redoing the kitchen and opening it up to include an open plan living area consisting of lounge/dining. This will also involve a new laundry (inc toilet and shower) and we also need to redo our current bathroom. After reading through a few posts I am a little confused. My plan was to get a draftsperson out and do some plans for us (not sure on what costing this is likely to be), and then get builders to come in a quote. I do have the original plans of the house that I got from the local council. I keep reading about building designers, that do everything. I honestly, didn't even realise that that existed! Are these the most common ways its done? TIA Re: Confused about starting a renovation 2Feb 06, 2016 5:26 pm Hi Goldencrumble, Which area are you based? I'm a draftsperson / building designer, personally it's hard to know what to call myself because they both can mean the same thing - it really depends on their level of services they offer. A building designer will create a design based on your needs and go through finishes and selections and giving you an overall 3d view of what your new renovation will look like. So concept drawings, to full working drawings for council approval with a colours and specification list - so the builder's know exactly what their quoting for, based on your selections. The draftsperson generally draws up what you are thinking and creates a plan ready for a quotation. Leaving it up to the builders to quote using their standard of finishes/ fixtures. Hope this makes sense. Feel free to message me if you have any questions. Cheers, Melinda McQueen Re: Confused about starting a renovation 3Feb 08, 2016 9:03 pm I think you're on the right track. Get a building designer or architect to do your design, then get quotes from 2 or 3 builders. Probably also a good idea to employ a building surveyor/certifier/quantity surveyor. Your building designer or architect should be able to recommend one for you. They can probably also recommend builders for you to approach to quote the job Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Confused about starting a renovation 4Feb 21, 2016 11:00 am I would recommend getting the surveyor about the same time you engage the architect/draftsperson. I made the mistake of engaging the surveyor after getting the draftsperson. The draftsperson had to wait till the surveyor completed the survey, before they could start drawing up the plans. Re: Confused about starting a renovation 5May 01, 2016 12:50 am I found it useful to have a builder come out first to have a look and flag any possible issues and confirm which walls were loadbearing. They can also give a good price guide straight up for what you're planning to do more accurately than a designer. My renovation blog: http://tashbell.com/ Or like me on facebook: Home of marble and mint Extending our 60's stonefront in Fulham, Adelaide Living through it all with husband and 3 kids Re: Confused about starting a renovation 6May 24, 2016 6:55 pm I would also recommend to contact a builder first and ask for the quote. This will help you in starting the renovation initially, focusing on your budget. This will also help you to know the total expenditure of your renovation and ofcourse will help you to have a better renovation too. If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8289 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5450 |
