Browse Forums Renovation + Home Improvement 1 Nov 11, 2015 2:39 pm Re: best way to attach white board to wooden bunk bed? 2Nov 11, 2015 3:45 pm If you look in the corners where there's the grey plastic piece you will notice circles that look slightly damaged. These are caps that cover the screw holes. You need to remove the caps and you can then screw straight to the side of the bunk. Holding the bottom will be the challenge. The pictures don't make it clear if there is anything at the bottom. If you post some additional photos I can help with options. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: best way to attach white board to wooden bunk bed? 3Nov 11, 2015 4:16 pm Can not take off the plastic. Will two 50mm F clamp suffice? Re: best way to attach white board to wooden bunk bed? 4Nov 12, 2015 1:17 am If you turn the board around are there holes in the plastic corner piece's? Normally those caps come out (you have to prise them out with a screwdriver) and then you screw them on. You would only use F clamps if it was temporary. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: best way to attach white board to wooden bunk bed? 5Nov 19, 2015 11:06 pm If you look at the corners where there is a plastic piece then you will notice about the circles that look little damaged. These are the caps that cover the screw holes and you need to remove the caps so that you can screw straight to the side of the bunk. Holding the bottom of the board will be the challenge. The pictures doesn't make it clear that there is anything at the bottom. 4 7187 Old Home Restoration / Renovation Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look… 2 2644 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 7104 |
