Browse Forums Renovation + Home Improvement 1 Sep 17, 2015 9:59 am First post, so hello all! I have built in an existing deck, all the framing and sarking is done and am about to install the weatherboards this weekend. Unfortunately it appears as though this crappy rainy weather is going to stick around for a bit and there is a chance there will be some light showers on the weekend. Is there anything wrong with installing weatherboards in the rain? They are 170mm CCA Treated pine weatherboards as an FYI and they are currently protected from the rain, but no doubt have a little bit of extra moisture due to the conditions. Re: Pine Weatherboard Installation question 2Sep 30, 2015 6:14 pm The weather boards will absorb water. Can you seal them before using them. Just wondering if you take a while to do the job the boards may not sit right when they dry out. 2 5923 1 19722 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6584 |
