Browse Forums Renovation + Home Improvement 1 Sep 10, 2015 2:49 pm G'day all, I am organising to remove the wall between the kitchen and lounge area though it is a load bearing wall (length 389cm). I am hoping someone might be able to advise the size of a structural beam required to handle the load for this length. It will be fixed by pro's though I am trying to resource the equipment and all required at better prices where possible. Cheers for any info or advice. Re: Structural Beam Sizing 3Sep 11, 2015 9:18 pm There are beam tables online. Goggle is your friend, but the span tables are not easy to read. Having some knowledge of how loads work will help you there. Re: Structural Beam Sizing 4Sep 25, 2015 8:16 am You will need a structural engineer! This is not something you want to play around with or take a guess! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Structural Beam Sizing 5Sep 25, 2015 9:09 am Hi HandyGuy You will need to Check/Engineers Certification for wind loads as well Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12986 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27415 |
