Browse Forums Renovation + Home Improvement 1 Sep 03, 2015 1:29 pm Hi all, Just wondering if someone could let me know the process (and possibly estimated cost) to get a full height opening turned into a doorway? We are currently building and have a FHO in our theatre room and laundry and are kicking ourselves because we should have put a door on the theatre to possibly make a future bedroom and one on the laundry to block noise. Is it possible to make these into doorways post build? Ceilings are 31c and all walls are brick. Theatre is 1060mm wide and laundry 1050mm. Any help is much appreciated. Cheers Re: Turning a Full Height Opening into a Doorway 2Sep 04, 2015 2:17 pm Fortunately it is a lot easier than going the other way! But brick wall will make matching the finish of the wall more difficult. Take a pick with a level sittingo n the slab and a pick with a level sitting on the sill please. This will help us diagnose the issue and therefore a solution. RE,… 8 9402 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9980 I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7093 |
