Browse Forums Renovation + Home Improvement 1 Aug 26, 2015 9:20 am It's a large unit - 520mm wide, 350mm and almost 600mm deep. Would I need to have some short timber "studs" (don't know the terminology) installed to provide structural support where the air con used to be or is it ok to leave it as is and just plaster and brick over it? TIA Re: How to repair hole in wall after box air con removed? 2Aug 26, 2015 9:47 am I'd put the extra timber in to give you something to secure the gyprock to. Just see if there's any insulation in the rest of the wall and if so, try and grab some off cuts from a building site to pack in to the opening, although that's not essential. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: How to repair hole in wall after box air con removed? 3Aug 26, 2015 10:08 am Thanks for that. Not much of a DIYer but at least now I know what's the best approach. Cheers. --- Watch out! I'm verbose. Re: How to repair hole in wall after box air con removed? 4Sep 02, 2015 9:19 am An inexpensive way is to fit a drywall to cover the hole where the old air con used to be. Then you can just paint the interior to make it match with the colour of your wall. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
