Browse Forums Renovation + Home Improvement Re: Trowel size 2Aug 15, 2015 8:40 am If you are talking the notch size as opposed to the actual overall trowel dimensions then for a floor tile you are probably looking at 12mm x 12mm. That will of course depend on what brand and type of glue you are using once again if you are glueing the tiles to a floor as opposed to a sand/cement bed and what the tiler prefers. Some like a smaller notch size like 8mm x 8mm. Your question is a bit ambiguous. Stewie Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7508 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3667 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3550 |
