Browse Forums Renovation + Home Improvement 1 Jul 14, 2015 4:44 pm I am embarking on a project to build a music room / studio in an old double-brick garage. I have gutted the garage and the first step is to put in a new ceiling. I plan to use Gyprock Soundchek, which weighs 13 kg/m2. The old ceiling was just thin masonite. My question is (1) Do the old ceiling joists need to be strengthened to take the heavier plasterboard? (I think they probably do.) (2) What is the best/easiest way to do this? Existing joists are old hardwood approx 25 mm x 90 mm and span across 3 metres with no support/bracing. They are approx 65 cm apart. See photos here: https://drive.google.com/folderview?id= ... sp=sharing Thanks! Re: Need to strengthen ceiling joists? 2Jul 16, 2015 12:05 pm The Timber Framing code specifies 125x38mm hardwood ceiling joists to clear span 3 metres so the existing ceiling joists are not strong enough. One solution is to install new ceiling joists of a suitable size to support the new ceiling, The nominal spacing of the new ceiling joists should be no more than 600mm. You may want to consider using softwood MGP10 120x45 as it is easier to work with. Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5843 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14644 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 16836 |
