Browse Forums Renovation + Home Improvement Re: bathroom floor sheeting 2Jul 16, 2015 10:25 am Im assuming you want to put the tile mat for waterproofing? The yellow tongue will be enough for a base. You don't need to apply another substrate on top but you will need to apply waterproofing. In a bathroom you will need to do this anyway so while you are at it, use it on the flooring and then apply bondtape around the edges. Then using an adhesive with rubber granules you would apply your tiles straight on top. Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5393 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8403 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11229 |
