Browse Forums Renovation + Home Improvement 1 Jul 07, 2015 9:27 am Anyone know if I can remove brick quoins on the side of my house without damaging the brickwork underneath? http://i786.photobucket.com/albums/yy141/sco77k/Quoins_zpsspd6fzg9.jpg Re: Removal of brick quoins? 2Jul 07, 2015 11:01 am It depends on what they have stuck them on with presuming they are the "stuck on after the brickwork has been done" kind. If they have used a decent kind of construction adhesive like Sikkaflex then they would be not only hard to remove but just time consuming. The hardest part would be trying to clean the adhesive off the brickwork afterwards. Stewie Re: Removal of brick quoins? 3Jul 07, 2015 12:28 pm These quoins could either be stuck-on mouldings, or rendered in place. Either way it would be a difficult process to get it back to original brick appearance. Re: Removal of brick quoins? 6Jul 08, 2015 5:57 pm Step 1. Remove the quad molding from the eaves Step 2. Remove the top few layers of bricks Step 3. Remove brick ties Step 4. Remove lower layers of bricks DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6337 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6713 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10256 |
