Browse Forums Renovation + Home Improvement 1 Jun 27, 2015 7:15 pm hi, i recently got this brick work done near the basement entrance of my house. I wanted your professional opinions on the work with what is wrong with it. Backstory. The concrete cracked over the winter and was falling apart so I needed to get it reworked and decided to have brickwork put in instead, but I think the job ended up being pretty bad. They had to match it with the existing brick work but it seems the spacing between the bricks are irregular, it is out of line and the bricks were cut poorly. I spoke to the construction guy and he stated that it was difficult to line the bricks up to existing brick work, and that it wouldn't have the same level of accuracy as building it from the ground up. He also said something along the lines of how hard it is handcut these bricks and that is why the quarter bricks are all messed up. I will be very honest, I don't know anything about brick work so I don't know if he is telling the truth. Please inform me of what is going on and what I actions I can take to remedy the situation. This is before Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is after The quarter cut bricks look real messed up. It isn't aligned with the previous brick work either, and spacing seems erratic. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the other side. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: need help with everything wrong with this brick work 2Jun 27, 2015 9:51 pm I have been a builder for over 40 years and your brickwork is about the worst I have seen, hope you have not paid up. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: need help with everything wrong with this brick work 3Jun 28, 2015 12:41 am Can you tell me what is wrong with it specifically? The guy explained that the side with the quarter bricks has a big space that needs to be accommodated for. Like if they aligned it with the old brick, there would be a hole about 1/4 of an inch from the door frame, and that would be unsightly. So they made an adjustment to accommodate for that space. Is that proper rationale? DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1168 2 31569 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18430 |
