Browse Forums Renovation + Home Improvement 1 May 20, 2015 5:45 am I'm about to destroy/ gut my ensuite. I'll be placing villa board on my walls before l tile. Do l need to place any tape on the joins or can l tile on top without doing anything. ( Except there will be waterproofing done) Any advice is good advice Re: Villaboard 2May 20, 2015 6:21 pm You answer will be in the installation manual from James Hardie. See chapter 6 http://www.jameshardie.com.au/uploads/file/20141111d6bd3c-Villaboard%20Lining%20Manual%20WEB%20-%20OCT%2014.pdf If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8318 Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 7480 |
