Browse Forums Renovation + Home Improvement Re: install gas hot water system in the shower room? 2Feb 25, 2015 3:04 pm For my HWS, the manual says it must be installed indoor. It is a storage tank one, so I assume they don't want it to expose to outside weather. And there is a small flue on top of it to discharge the exhaust. I just don't know if this whole system can be put in the bathroom or not, as I assume it may require much air while running. Re: install gas hot water system in the shower room? 3Feb 25, 2015 5:50 pm Yes it can be done and will require fixed ventilation the sizes of which will be different depending on whether the ventilation is direct to the outside or from another internal room , your plumber will be able to size this for you and guide you to the best location ( if not you better get one that is capable ) . I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 16157 The time to heat is purely a function of the distance between the hws and the faucet. There are many options for hot water, you can also have a circulating circuit of hot… 1 8661 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 18071 |
