Browse Forums Renovation + Home Improvement 1 Jun 15, 2015 10:16 pm I have a 50's brick veneer house in Melbourne which I purchased in 2014. Shortly after we moved in I had the floors sanded and polished. Prior to this it looked like the floors hadn't been sanded as carpets were laid but I could be wrong. Anyway a couple months after the floor was sanded I noticed a few spots that squeaked. Upon further looking the boards are flexing between joists. The total area is approx 70sqm and I have approx 20 boards which squeak and flex. I employed the services of a flooring professional but suspect he has over sanded the floor. Question 1: How can I tell if the floor was over sanded? Question 2: can I stop the boards flexing, liquid nails from beneath? Question 3: what are the chances of getting compensation from the tradesman that did this? Re: Floorboard flex after sanding 2Jun 17, 2015 10:02 am The sanding has nothing to do with it. Board flex between joists is common, and just shows that your house was a budget build (like so many). The sander should have put plenty of urthane in the board gaps during the polish stage, to glue them together and thus stop them squeaking. Nevertheless there are other issues which could be the cause. There are various ways of shutting them up, but without seeing them, its hard to say what method to use. Re: Floorboard flex after sanding 3Jun 17, 2015 10:55 am You may just be the third or fourth owner who has had the floorboards sanded. Each time they take off another couple of mm so your original 20mm floorboards may be down to 16mm now and nearly all the way through to the T 'n G joins meaning that the floorboards may be undersized for the span between floor joists. Re-nailing the squeaky floorboards may be the only way to stop them but this should have been done prior to sanding and finishing them. Hard to blame the floor sander for any of this. Either that or wriggle underneath and try to locate the offending boards and pump in some construction adhesive to any gaps. Stewie Joe Apologies for the delay in getting back to you. If you haven't sorted this already you need to caulk this gap. Not sure where you are but if you are in Sydney I can… 5 4698 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5800 Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 12554 |
