Browse Forums Renovation + Home Improvement Re: extending alfresco roof 5Feb 08, 2015 3:59 pm ntonk Hi goody59, Not sure what state you are in but I am a building officer here in SA and any attachments to existing roofs needs approval regardless of the size. If the attachments are less than 4m, you can avoid having to get an engineers report and can use rafter strengthening brackets or timber stiffeners at max 1200 centres. The length of the brackets/stiffeners depends on the eaves/wall but generally 1500 would be sufficient. I know this doesn't answer all of your questions but I hope it helps! That is some great input, thanks for the reply too. If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 2655 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 679 There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 2287 |
