Browse Forums Renovation + Home Improvement 1 Feb 05, 2015 10:21 pm Hi I just re-carpeted and repainted my living room. I have an old white standing shelf that i want to break into separate wall-shelf's. Here are some pictures which should depict where I currently stand with my living room and maybe even show some possibilities of what am I able to do with my shelf. Is it a good idea to attach the shelf's to the wall where the painting is? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [shelf would go where the painting currently hangs] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [fit's 60 DVD's] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [fit's 2 rows of DVD's; should I cut the shelf in half? perpendicular or longitudinal cut? maybe both cuts to reduce the weight? best tools to do such thing?] Things to note: plaster wall (not strong), I can remove the painting, I have many useful tools to convert the shelf, I can fit 60 DVD's on one of those 4 long pieces of plywood - which will be pretty heavy, I can also check how much weight will it be altogether per shelf if it's needed. I don't have any silicon or glue or supporting stands to attach the shelf's to the wall. This is where I also need your help; what's the best way to attach these shelf's to the wall? Bunnings is right around the corner so tell me what should I pick up there. Any help is appreciated. Thanks, John. From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 4713 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 1183 Because it only states 90mm not if it’s 45mm or 35mm and yes I do have the plans my question was specifically since it’s not the structural value and only to hold… 2 2156 |
