Browse Forums Renovation + Home Improvement 1 Jan 18, 2015 3:37 pm So basically we ate looking to gut our boxy downstairs rumpus area and put big bifolds out to the garden however I just noticed there is a household drain with the pipes from both kitchen and bathroom right in the middle of where we want the door space. There is another one a few meters away , could we redirect all pipes into the one drain? There'd be 5 maybe 6 sinks, a bath and a shower into the one drain. Alternatively on the outside is the downpipe from the roof but I guess that goes to storm water not treatment plant. Help! Re: HELP! Can I move a drain?! 2Jan 18, 2015 8:50 pm You MUST employ a plumber...and downpipes do go to stormwater. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: HELP! Can I move a drain?! 3Jan 20, 2015 10:17 pm You do need a plumber as suggested. Certain diameter pipes can only run so far without venting. If they are over run it could cause poor drainage or even a vacuum in the lines. The ORG locations really need to be assessed by someone who knows what's going on I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 3783 3 5131 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 3443 |
