Browse Forums Renovation + Home Improvement 1 Dec 01, 2014 4:48 pm Hi everyone, My family and I are about to reside portions of our home which have rotted. As we have never undertaken a DIY project like this before we are coming up with lots of questions. In regards to the area around our windows which will also need replacing (see image) http://postimg.org/image/3xsan9ir5/ I'm no expert but it appears that the person who added this extension on has merely stuck the windows onto the exterior of the wall rather than insetting them meaning that the surface of the window frame is a good 20-30mm out from the wood siding. As you can see the wood molding doesn't even reach the frame and water pools on the little shelf it creates - I assume that the molding should be raised so that water runs over the window rather into it. Does anybody have any suggestions to how this could be remedied? Thanks Nick, Re: Exterior Siding Advice 2Dec 02, 2014 4:48 am the window will come out easily by the look of it. Is the inside of window frame leaking damaged? If so remove window , pack frame to suit , refit window or purchase new window. re-clad exterior. The width of the window reveals(wood around window frame) looks to wide for the frame / studs of house. If so trim reveal down to size when ya get it out. Design from top down to ground , build from ground up Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15860 Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4474 |
