Browse Forums Renovation + Home Improvement 1 Nov 29, 2014 10:00 am Hi everyone, Do any of you know if it is possible to use a self-levelling compound over a slab that was originally coloured? I have been reading the data on a few of the self-levelling products and they say there should be no curing compounds (along with many other things). I remember when the slab was laid and we were helping to disperse the colour, the concreter said that it also cures the concrete more quickly. I guess that means it is a curing compound??? I want to tile it all now, and the problem is that to attempt to grind it away would mean a few mm, and that would be a pain. Does anyone have any knowledge in this area? I would appreciate the input. Thanks in advance. Re: Self-leveller over coloured concrete slab?? 2Nov 30, 2014 6:35 pm Hi, no answer to your specific q - however - if you do go to grinding the top layer off can I tell you about a machine we used? It's a concrete mower (I think) designed to scrape paint off concrete - we needed a perfectly level & smooth surface to run floating floor boards after lifting slate (don't go there!) and this machine, hired from Kennards, was exactly what we needed. Took the top 2mm off and left a perfectly smooth surface. We leveled with a slurry of concrete then scraped this back. It has a circular diamond tip blade but otherwise resembles a mower. Rebecca Jarrett-Dalton Property crazy expert mortgage broker, love building new homes! Two Red Shoes mortgage broker http://www.tworedshoes.com.au/building Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one… 0 6538 One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 656 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6244 |
