Browse Forums Renovation + Home Improvement Re: Defect in VIc Ash Timber Floor? 9Nov 19, 2014 2:03 pm B STAR If this is being installed onto plywood they are not doing a good job. Yes it will look fine after they fill with putty and polish it but it will not be perminate and the putty will eventually fall out. absolutely do not fill with putty! If you are going to accept it, just polish as is. If you want the gap filled, get a tin of urethane and a big syringe, and keep going filling the gap until it is proud. Its the flashing and is normal. Some builders cover them up others just leave them handing. You can cover it up with an aluminium bracket or ask the builder. 7 11233 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5339 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10148 |
