Hi,
I'm after external render bead, both corner and stop beads. However Bunnings and H&G don't sell it.
Can anyone recommend anywhere around Manly Vale/Brookvale which will sell it?
Cheers
Alex
Browse Forums Renovation + Home Improvement Re: Where to buy external render bead? 2Oct 13, 2014 1:09 pm FYI for anyone else, managed to get stainless steel beads from www.gyprocktrade.com.au 36 Chard Road BROOKVALE NSW 2100 Phone: 02 9909 6900 Re: Where to buy external render bead? 4Oct 14, 2014 7:41 am Stainless ( preferred ) or plastic should always be used when you live not too far from the coast. I worked on a house about fifteen years ago and the plasterers used standard metal corners on the outside of the house when they cement rendered it. The house was only about 300metres from the ocean. Five years later every external corner was rusting badly as you would expect. Stewie Re: Where to buy external render bead? 6Oct 14, 2014 10:19 am To my knowledge acrylic wasn't used back then by many of the plasterers around here unlike these days where it seems to be the preferred method. Certainly not by the guys who did that house. I remember pointing out to both the homeowner and the renderer the problem of using ordinary metal corners that close to the ocean but I was fobbed off by both of them. Stewie Looking at some of the designs on websites, they are all selling very similar products. I get that you want something stylish. It's worth looking for search terms like SaveH2O… 2 7006 Before you rip it up, if you can in the grout lines, drill some holes and pour/inject techgrip by sika. I have used it to bond mdf to timber, but in the process it dripped… 1 4290 |
