Browse Forums Renovation + Home Improvement 1 Sep 30, 2014 8:07 pm Hi guys, I'm looking to build a permanent Alfresco on the side of my townhouse. It will be undercover with a tiled roof and I basically would like to deck it out with an area equipped for a BBQ including rangehood and a sink for food preparation. Unfortunately a main sewer pipe runs through my property and I have been told by South East Water that I am able to build the Alfresco however, I will need to remove the BBQ/kitchen from the design otherwise it will not be approved. Apparently, they do not allow for a sink to be build within close proximity of an easement. Does anybody know what the reasoning for this is? Can anybody give me suggestions for an alternative as i am not able to plumb a sink near the main sewer pipe? Re: Alfresco with kitchen 2Oct 07, 2014 2:21 pm Hi Pedestrian, If you are building over an easement, which it seems you are, then buildings in that situation must be class 10 I think. Verandahs, and sheds and carports are OK but not habitable rooms I think. Hope this helps, Leonardo_23 no need, you’re trying to keep the liveable spaces insulated, the roof cavity is “outside” and the temperate is same as ambient 1 27048 Hi guys, I am looking to cover my large alfresco sections with something to prevent dust/leaves getting in and also to cover from rain coupled with gusty wind. My goal is… 0 42599 I’d look at doing a self-leveling compound with a slight fall + waterproof membrane before even thinking about tiling. And if you can add a strip drain or some sort of… 3 13236 |
