With a clourbond roof is it better to use the gal steel top hat type purlin /roof battens.
or
use the h2 mgp10 pine.
Just had some concerns of moisture and whats the better option.
ty
wobbly
Browse Forums Renovation + Home Improvement 1 Sep 05, 2014 3:39 am With a clourbond roof is it better to use the gal steel top hat type purlin /roof battens. or use the h2 mgp10 pine. Just had some concerns of moisture and whats the better option. ty wobbly Design from top down to ground , build from ground up Re: Purlins? 3Sep 05, 2014 10:47 am Ty mgilla, had a prob with ya meaning, maybe just a typo. But i was planning on using mgp10 90 x 35 rafters with the top hat purlin as the battens. Instead of using mgp10 for battens. could you clear it up a bit for me wobbly Design from top down to ground , build from ground up Re: Purlins? 4Sep 05, 2014 4:16 pm Sorry that was a bit of a convoluted answer. Should have read "If your putting blanket under the tin then go with top hat metal battens" Your rafter size will be determined by the span so I dont know if 90x35 is suitable, there are span tables online that will tell you pretty quickly what you need. Cheers mgill |
