Browse Forums Renovation + Home Improvement 1 Aug 07, 2014 9:45 am Hi, Planning on fully rendering our house, but our garage and the neighbors garage are both on the boundary line, so only about 20-30cms between the 2 brick walls, Are renders able to do our garage wall? with that limited space? Re: Rendering between garages 2Aug 07, 2014 10:49 am If the neighbours garage is already built then no you won't be able to render the garage wall. If your neighbour has not yet started building their garage you can render the garage wall, but you will need to get their approval for this and they will need to give you access to their property. My build: viewtopic.php?f=31&t=68002 DIY, Home Maintenance & Repair Unless you have a damp issue, either failed waterproofing in a wet area, a leaking pipe or rising damp, moisture shouldn't be an issue. You can usually tell if you have… 5 8149 ![]() Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 1579 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 1752 |
