1. Is this correct- If its under 25sqm it is exempt development. It'll probably be closer to 30sqm, but would you make it a bit smaller just to avoid having to deal with council? or is that crazy talk? I am meant to get a copy of the aus building codes for jobs like this?
2. Under deck ventilation/drainage/grass. Thinking the deck will be approx. 30cm off the ground. What do you do about ventilation/access to check for termites? It seems to small to climb under and have a look? Is there enough ventilation just in the slats between the boards? Can I put garden beds/steps all around the facing of the deck ( I mean between the top of the deck and the ground at its front), or will that inhibit air flow too much? We live on a soggy block and have had some issues with mold/sogginess under the house. Do I just cover the grass with plastic and gravel?
3. I am reluctant to mess around with attaching anything to the double brick. Will it work to run bearers parallel to the house ( not touching), so essentially its a free standing deck? The pergola will attach at the top though.
4. Has anyone used the recycled plastic decking boards? Any good?
Thankyou kindly
