Browse Forums Renovation + Home Improvement 1 Jul 16, 2014 5:31 pm Thanks guys. First post We are selling our house. this was a new build from porter davis and has been a nightmare We are trying to sell but have been told the retaining wall installed at construction should have fall protection. The wall is on one side of the house about 3 meters from the fence and because the height. the drop to the lower ground level is 1.7 Meters (and its largest) it was illegal and a fall protection should have been installed Can anyone give me some advice? should there have been one installed at build? Thanks Re: Retaining Wall - Fall protection 2Jul 16, 2014 11:03 pm Yes. Anything over 1m you need a handrail. A lot of retaining walls and terraced gardens the authorities tend to turn a blind eye but 1.7m is pushing it a bit. Stewie Re: Retaining Wall - Fall protection 3Jul 17, 2014 1:37 pm What Stewie said.... Just bang up a handrail and you can rest easy. Depending how long it is, it shouldn't cost much to put up something that complies to the regs and looks great. Re: Retaining Wall - Fall protection 4Aug 14, 2014 12:34 pm I would consult Masters builders or local council in regards to what they think about the site being left like this? Did your builder do the wall? Icon Walls www.iconwalls.com.au Engineered Retaining wall products 2/64 Bennet St Dandenong 03 9792 1476 Re: Retaining Wall - Fall protection 5Aug 17, 2014 9:08 am jasonemp Thanks guys. First post Can anyone give me some advice? should there have been one installed at build? Thanks What sort of retainning wall is it ?....I would doubt that the Builders engineering drawings shows Balustrade/Fencing (although mine do) which is generally installed by the fencing contractor. IMO,the Building Contracts & Codes dont adequately deal with Non Compliance Unfortunately, In some cases the balustrade can cost as much as the Retaining Wall and now the Council/Building Surveyor may now insist that it is properly certified and installed/built. OT the same goes with elevated decks + balustrades Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Retaining Wall - Fall protection 6Aug 17, 2014 11:52 am Sorry but without seeing a photo it's hard to judge but I'm reasonably confident the advice you've received is incorrect. As far as I can recall a retaining wall DOES NOT require a balustrade unless it is associated with a path or travel between buildings. There is an exemption in the BCA for retaining walls. I don't have a copy handy but can check later. Completed a knock down and rebuild in northern Melbourne. Handover completed 27/09/2013 and now moved in. Re: Retaining Wall - Fall protection 7Aug 17, 2014 11:59 am i.e. Unless you've got a formal delineated path running alongside the top of the retaining wall, then you're good without a balustrade. Completed a knock down and rebuild in northern Melbourne. Handover completed 27/09/2013 and now moved in. Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4698 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18413 |
