Browse Forums Renovation + Home Improvement 1 Jul 01, 2014 9:16 pm We are renovating a house with existing dark grey/almost black slate with a slight red slash through it. We have removed the carpet from the living/dining area and need to replace it with another flooring option. The house will be a pet friendly rental once the renovations are completed so re carpeting isn't an option. Any suggestions on a flooring solution to compliment the existing slate. I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 3335 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 383 just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue… 1 319 |
