Browse Forums Renovation + Home Improvement Re: Help with roof design 8Jun 21, 2014 3:15 pm Actually is there anything wrong with this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Should work with your early hip design as well? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I found this link which has something similar http://www.builderbill-diy-help.com/hou ... nsion.html Re: Help with roof design 9Jun 21, 2014 6:58 pm Quote: Is that last design still 22 degree? Would it make things easier overall if we end up changing to colorbond and can go lower? Yes all 22º. It would end up being much the same no matter what the roof covering. You can go down to 7º with CB but I think thats too low. I wouldn't have anything less than 15º and even that might not suit the style of your house. Quote: Also, ignoring the hips for a moment, would something like this work? (I guess not since the height of the gutter at that short valley would be too high?) Yes, but I think no matter what you choose you should consider what it looks like from the front - all the other sides don't matter anywhere near as much. Stewie Re: Help with roof design 10Jun 22, 2014 8:30 pm Stewie D Yes, but I think no matter what you choose you should consider what it looks like from the front - all the other sides don't matter anywhere near as much. Yeah I think hip looks better overall, though some gables are nice as well. Not sure if you saw the hip designs in my last post, but it looks like that should work. Re: Help with roof design 12Jun 22, 2014 10:05 pm Sorry that was poorly worded, what I mean is we are making that inside part of the U fatter, which is where we have extended past the previous wall by 2.5m or so (see the blue lines for the existing wall). So we aren't filling the whole "U" in, but we are extending a little inside it which is why we can't keep that part of the roof as is. Re: Help with roof design 15Jun 30, 2014 6:31 am I work with roof designs all day, every day. I am very impressed stewie, well done... steve@everlastpatios.com.au www.everlastpatios.com.au G'day I'm trying to put in some privacy screening on my rental rooftop on a tight budget. I've already invested about $500 in the supplies for this. The issue is… 0 32262 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19581 Although I am a big opponent of using waffle pod slabs over H2/P soils under any circumstances, in your case I would certainly opt in to keep piers under central… 1 2450 |
