Browse Forums Renovation + Home Improvement 1 Jun 16, 2014 11:02 pm Hi, I have started adding an extension to my house and my plumber has asked about a permit to connect for the sewage works. I find the YVW site only specifies new developments and new connections. Since I am only replacing my existing sewage pipe i.e.. not a new connection I was wondering if I need this? Can anyone give me more information about this requirement for existing connections please? Will try to contact YVW tomorrow Thanks Tim Re: Do I need permission PIC to replace old sewer pipes and 2Jun 18, 2014 10:24 am As you said, new work requires a permit. If the sewer pipe is your responsibility (usually that portion that extends beyond the sewer mains stub), then replacing existing only requires the person doing so to be a licenced plumber/drainer. But since you are doing an extension, it implies it will house a plumbing fixture? Meaning new work? 4 5099 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10181 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10805 |
