Browse Forums Renovation + Home Improvement 1 May 27, 2014 7:29 pm Is this even possible to add a loft to a pre existing brick and tile house in WA? Has anyone done this and could it be done without vacating house. Also any ideas on cost. This is a thought process right now, have no idea if it is feasible or even possible. The loft would ideally be a games/tv room for kids and possibly a bedroom. No plumbing. Thanks Re: Adding a loft extension in WA 2May 27, 2014 7:56 pm It is definitely possible. As for cost sorry can't help. Try summit home improvements, dale alcock improvements etc Re: Adding a loft extension in WA 3Jun 03, 2014 1:45 pm Hi bytheseaside I can have someone get in touch to discuss this with you if you'd like? Dale Alcock Homes. We love building. T: 08 9242 9200 Mon – Fri 8am-5pm Sat - 10-4 thedacrew@dalealcock.com.au http://www.dalealcock.com.au http://www.facebook.com/dalealcockhomes Re: Adding a loft extension in WA 4Jun 03, 2014 5:13 pm there is also a mob called Attix here in Perth Re: Adding a loft extension in WA 5Jun 04, 2014 10:38 pm It can be done, but if you chose to use it for a living area rather than storage, but first you got to see if its feasible depending on your roof angle and height, what obstacles need to be re-located to make room etc. Remember, there are regulations for minimum roof space heights that determine if you can go ahead with this. You can still live in your house per se while people are in/out working on it but that's more so a personal choice Cost varies a lot based on size, and then how you want it finished, do you want windows? Generally 20,000 to $50,000. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: Adding a loft extension in WA 6Jul 28, 2014 1:04 pm Even for storage, would the existing ceiling joists need to be reinforced/supplemented to handle frequent foot traffic? Ive given thought to creating a 3x4m storage area in my roof space. The existing brick internal walls are strong enough to hold up. But the existing ceiling rafters are 90x35mm pine beams only intended to hold up the gyprock! Re: Adding a loft extension in WA 7Jul 28, 2014 1:11 pm dexx Even for storage, would the existing ceiling joists need to be reinforced/supplemented to handle frequent foot traffic? Ive given thought to creating a 3x4m storage area in my roof space. The existing brick internal walls are strong enough to hold up. But the existing ceiling rafters are 90x35mm pine beams only intended to hold up the gyprock! yes- what sort of span would they have? 3-4m span would require substantially more then 90x35 pine. Re: Adding a loft extension in WA 9Aug 15, 2014 3:30 pm Hi ByTheSeaSide How old is your House and do you have the Drawings/Structurals, is the roof frame structure Timber or Lightsteel Trusses? In new houses generally internal wall slabs aren't thickened and the walls are non Loadbearing fastwall. It is possible to use lightweight materials but by the seaside consideration must be given to the coastal environment, durability, wind loading etc. It is best to get your house properly inspected first and then look at what options are available ie, Pods, Prefab, Timberframe, SIP.etc and get quotes.....HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4709 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8463 |
