Browse Forums Renovation + Home Improvement 1 May 25, 2014 3:27 pm Is it necessary to vacuum and clean out the existing Floc Insulation before insulating with the bat style insulation. Some of the installers who have given us quotes have said that it is sufficient to place the new bats on top of the old insulation. Is this true?? Re: Insulation Retrofit with existing Floc Insulation. 3May 25, 2014 8:56 pm It depends on how dirty your existing ceilings are. If they are pretty bad I'd remove everything , give it a good clean ( with an approved vacuum ) and install the new. If the ceiling is Ok, I'd just go over the existing insulation with the new as you'd end up with a thicker total layer. Just make sure you follow all the safety precautions and make sure you don;t cover any downlights with the batts. As an aside , do you know what the existing insulation is made from ? Most was made from cotton from memory but some was made from not so eco- friendly material. Stewie Re: Insulation Retrofit with existing Floc Insulation. 4May 28, 2014 11:07 pm JWFino+1 Is it necessary to vacuum and clean out the existing Floc Insulation before insulating with the bat style insulation. Some of the installers who have given us quotes have said that it is sufficient to place the new bats on top of the old insulation. Is this true?? We had old insulation similar to yours. We got ours vacuumed out and bats put in. It made it easier for the installer and removed alot of vermin droppings. Re: Insulation Retrofit with existing Floc Insulation. 5Nov 24, 2014 11:47 pm freakychick JWFino+1 Is it necessary to vacuum and clean out the existing Floc Insulation before insulating with the bat style insulation. Some of the installers who have given us quotes have said that it is sufficient to place the new bats on top of the old insulation. Is this true?? We had old insulation similar to yours. We got ours vacuumed out and bats put in. It made it easier for the installer and removed alot of vermin droppings. Did you have it tested first to ascertain what it was? 1 19708 4 11183 I am saying that double brick has similar thermal performance due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15… 10 29740 |
