Browse Forums Renovation + Home Improvement 1 Apr 13, 2014 1:39 pm Hi there!
We are looking at changing the floorplans of this house to turn it into a 3 bdr + study and would appreciate ANY ideas or tips. My partner and I are not very 'visual' people so we are having trouble being able to visualise or ideas and whether there could be great ideas we have overlooked. These are the changes we are thinking of - Lounge - making a boxed entry and then turning the rom into the master bedroom - closing the external door access to bed 2 - closing the door access in bed 3 into the family/dining - moving the bathroom into the laundry - bathroom becoming a study nook with no door - laundry to be placed outside with a boxed room in undercover(completly enclosed) area adjacent to existing laundry room - window in family/dining room changed to sliding door so as direct access to undercover area. We would appreciate ANY feedback as we are complete newbies to this kind of thing. TIA Jodie [img][IMG]http://i1278.photobucket.com/albums/y514/jodesGod/floorplan1_zps42dd5b89.gif[/img][/img] Re: Ideas on Changing floor plans 2Apr 13, 2014 1:57 pm Have you attached the floor plan? I cannot see it in your post. Re: Ideas on Changing floor plans 5Apr 13, 2014 6:51 pm I think your suggested changes are good. I was a bit concerned about swapping the bathroom to the laundry, but the floor plan is deceiving - it's only .1 difference in width where are it "looks" like a lot more on the plan. Making the entrance boxed in to create the first bedroom, along the boxed in wall you could put a built in robe. I would also consider trying to make the toilet separate (not inside the bathroom) as it is a one toilet house and sucks if you need to pee while someone is in the shower. Re: Ideas on Changing floor plans 6Apr 13, 2014 7:12 pm joyfulbuilder I think your suggested changes are good. I was a bit concerned about swapping the bathroom to the laundry, but the floor plan is deceiving - it's only .1 difference in width where are it "looks" like a lot more on the plan. Making the entrance boxed in to create the first bedroom, along the boxed in wall you could put a built in robe. I would also consider trying to make the toilet separate (not inside the bathroom) as it is a one toilet house and sucks if you need to pee while someone is in the shower. Thanks so much @joyfulbuilder for your feedback. Yes the floorplan is deceiving with the size of the laundry. With the way the front door opens we are limited with the master bedroom door so the built in robe is a great idea however that wall has 2 windows. I love the idea of a seperate toilet and we will keep the brain ticking with how that could be done. We are also thinking of trying to build an ensuite in the master bdr but are unsure of whether there will be enough space?? Thank you again for your feedback Re: Ideas on Changing floor plans 7Apr 13, 2014 10:00 pm I meant the built in robe on the other wall (backing onto the other bedroom) - but having another look, that would mean the bedroom door would be "behind" the front door, which wouldn't work. Will you remove the door from the original lounge into that little hallway? Re: Ideas on Changing floor plans 9Apr 14, 2014 11:35 pm Good basic floor plan, easy to do renovations too... - box in first bedroom - great idea - create long hallway. - demolish walls between bed 1 and family/dining - demolish wall between bed 1 and kitchen - open up kitchen, long galley with an island bench that looks out onto the dining room (that was previously bedroom 1... - create a big open space at the back. - keep wall between bed 1 and current hallway to help with noise and so the bedroom 2 isnt opening up to the open living area The key question for me is the orientation (north/south etc).... and which outdoor area would you use the most? Re: Ideas on Changing floor plans 10Apr 15, 2014 8:50 am Thanks for the ideas! I would love to make the kitchen area more open plan but I would lose my 3rd bedroom. Is this what you were suggesting? I have 2 children so really need the bedrooms The front and back outdoor areas are both lovely yet the back is completely enclosed so it doesn't have the open feel like the front. We were thinking if making the back area more like a play area at one end and the laundry at the other. There is a spa out there too that is currently placed right near where we want to put the sliding door ( dining room window) . Thanks for the ideas I never really thought about taking walls out but as it is, that 3rd bedroom does not have a window ( only a skylight) Re: Ideas on Changing floor plans 11Apr 15, 2014 10:35 am I will do up some rough plans today for you, and go from there… I see what you mean about the bedroom. I'll have a look at that. What orientation is the block (north south etc). Re: Ideas on Changing floor plans 12Apr 15, 2014 10:51 am The front of the house is facing SW. There is alot of shadecloth coverings around the front outdoor area so it looks like that gets the afternoon sun. There may be the option to make a bedroom at the end of the family room and then take the wall down between Bed 1 and the kitchen and have that as the dining room like you mentioned and have the family/dining as the family room only? If that makes sense Re: Ideas on Changing floor plans 13Apr 15, 2014 2:28 pm - good light - open plan living area - creation of hallway to aid privacy for main bedroom 1 - could create cupboards where bathroom is now along wall for laundry… depends if you want a separate laundry, and create a bigger bathroom - we have 1 toilet in bathroom and it does us fine for family of 3 just have to be considerate. - this plan means no addition of windows and only internal walls (and potentially supporting beam across kitchen… - bi folds or sliding doors could be added to walk out on deck do you have photos of your place? drawings below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Ideas on Changing floor plans 14Apr 15, 2014 2:30 pm a door should be added close to bed 2 to allow walking from bed 2 directly into living/lounge area… beauty about this plan is it's north east, so lots of light, and kitchen looks out directly over the lounge area… creation of north east bedroom wall allows tv to be placed there Excelling excelling height so this space will look very very large. Re: Ideas on Changing floor plans 15Apr 15, 2014 2:41 pm I think jonas has done a cracking job using the space you have! The only amendment I would make to that would be to squeeze in a 3-way bathroom rather than havin it all in the one space. The questions that I'd ask are: 1. Are you planning on settling into this house (in which case you should assess what your needs are and make the space work for you) or are you looking to renovate and flip it (in which case there are certain features that are very marketable and should be considered - depending on the price point and area). 2. Are you looking at adding on extra floor space with an extension or just reconfiguring what you already have? Are you looking to use the shed space as another living/recreation area? My building thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=56583&start=120 Re: Ideas on Changing floor plans 17Apr 15, 2014 5:19 pm The plan looks great Jonas! I had not thought of making the hallway all the way to the new bedroom. I have a plan that we fiddled with but was wondering how I can put that in my post like you did? I have only found how to put the link in?? Cheers Jodie Re: Ideas on Changing floor plans 18Apr 15, 2014 5:56 pm have you got a scanner? even if you took a photo on your mobile, then uploaded it to http://postimage.org/ Then attach the link This plan means all bedrooms get good light with the space. Alternatively you could flip it, but this way it's not as much cost with moving fixtures, plumbing, gas etc... Would love to see your plans, hopefully you can organise to upload. Re: Ideas on Changing floor plans 20Apr 15, 2014 8:25 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This was the first lot of changes we were thinking of but now after Jonas' ideas about making the place more open plan and a hallway to the new bedroom i will have to rethink The shed is not that close to the house either in the original plans. As you can see we were thinking of moving the laundry outside to an outside room since it is all enclosed on the verandah. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11933 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5540 Hi all, I've received the unwelcome news that our certifier (BCA Certifiers) has merged into the McKenzie Group. A quick Google revealed McKenzie is the mob that… 0 4245 |
