Browse Forums Renovation + Home Improvement 1 Apr 04, 2014 6:13 am Hi This is something I hadn't thought about before. When putting up a new internal wall, is it best practice/required to remove the plaster board above the top of the studwork or just leave it sandwiched between the rafters and the stud. In the UK we leave the ceiling plasterboard in place. Just wanted to check there wasn't any regulations etc. Cheers Re: Studwork to ceiling 2Apr 07, 2014 11:13 am Hi alexf40, I am not aware of any regulation that would make you remove the ceiling plasterboard. I assume that you would be addend a cornice to hide the joint between the wall and the ceiling. The only time when these sorts of things come into play is when you are creating 2 separate dwelling units. That is when you need fire separation and it becomes an entirely different situation. If it is just a new wall in a house or apartment then no problem. I hope this helps. Cheers, Jenny. Need hints, tips and inspiration? Join me on my Facebook page: https://www.facebook.com/ournewhomecoach Who am I? See my LinkedIn page: http://www.linkedin.com/pub/jennifer-crawford/1a/429/296 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5936 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17198 |
