Browse Forums Renovation + Home Improvement Re: Hinge door to sliding door at wardrobe 2Oct 28, 2013 5:57 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Hinge door to sliding door at wardrobe 5Oct 29, 2013 5:37 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Hinge door to sliding door at wardrobe 6Oct 29, 2013 5:50 pm Thanks guys Just to clear, I am saying about cavity door. I am looking for those which slide over each other. I got two door for that wardrobe My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 700 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3075 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4905 |
