Hinge door to sliding door at wardrobe
I am looking for changing my wardrobe door. It's hinge door but I want sliding. I want to do myself , is it hard and where to get all the material ,, what material I will need???
Photos of your existing wardrobe would allow for people to give some real advice!
I am looking for cheapest option
Just make sure you have the right height. If the doors a a bit wider they can overlap a bit.
You need to buy the channel and the doors. Not cheap unless you can find them second hand on Ebay. Not hard to put in.
It really depends on the construction of the existing wardrobe. It could be quite easy but it could also be very time consuming depending on how it was built.
This is why a photo is the only way of getting answers that are correct and not guesses!
Just to clear, I am saying about cavity door. I am looking for those which slide over each other. I got two door for that wardrobe
My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and…
8/08/2023
3
Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the…
11/09/2023
6
Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused.
