Browse Forums Renovation + Home Improvement 1 Oct 26, 2013 7:09 pm Hi I am looking for changing my wardrobe door. It's hinge door but I want sliding. I want to do myself , is it hard and where to get all the material ,, what material I will need??? Re: Hinge door to sliding door at wardrobe 2Oct 28, 2013 5:57 pm How long is a piece of string?? Photos of your existing wardrobe would allow for people to give some real advice! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Hinge door to sliding door at wardrobe 3Oct 28, 2013 6:09 pm It's normal wardrobe with 720mm doors and 2040mm height. I am looking for cheapest option Re: Hinge door to sliding door at wardrobe 4Oct 29, 2013 5:07 pm You need to buy the channel and the doors. Not cheap unless you can find them second hand on Ebay. Not hard to put in. Just make sure you have the right height. If the doors a a bit wider they can overlap a bit. Re: Hinge door to sliding door at wardrobe 5Oct 29, 2013 5:37 pm travelbug You need to buy the channel and the doors. Not cheap unless you can find them second hand on Ebay. Not hard to put in. Just make sure you have the right height. If the doors a a bit wider they can overlap a bit. It really depends on the construction of the existing wardrobe. It could be quite easy but it could also be very time consuming depending on how it was built. This is why a photo is the only way of getting answers that are correct and not guesses! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Hinge door to sliding door at wardrobe 6Oct 29, 2013 5:50 pm Thanks guys Just to clear, I am saying about cavity door. I am looking for those which slide over each other. I got two door for that wardrobe My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 1607 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3468 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 5637 |
