Browse Forums Renovation + Home Improvement 1 Jul 13, 2013 12:19 am Hello, Currently in my garage boards that are covering repair channel are loose on top of that channel. I want this to be safer. Currently nothing is preventing the boards from moving and falling into the channel. This is dangerous for me and for my family. I would like to get the boards on top of the channel in a way that they would be flush with rest of the garage floor. For that I would have to attach a steel corner to the edge of repair channel to support the boards. Under the channel edges there are no support walls and support is provided by two U-beams. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ On the left there is the edge of the repair channel and on the right the front view to the garage. My initial plan was to attach the steal L beam with 8mm concrete anchors (500mm spaces). That would be 8 anchors per side. This would mean that I'd have to drill holes to those supporting U beams. The holes would be small and would locate almost in the center of the beams but still I don't feel confident in drilling structural support beams. What is your opinion, will it decerease the structural integrity of the floor (or the beams) considerably? Re: Attaching car repair channel cover boards 2Jul 13, 2013 10:36 am Drilling through the U beam might prove difficult with hitting reo. But if you must go this way, beefing up the thickness of the angle would allow fixing spacings to be doubled, however I would stitch arc weld the angle in place -- although it might prove painful when bumping into it. Why not stitch-weld some square or rectangular section instead? Arfur Re: Attaching car repair channel cover boards 3Jul 16, 2013 5:34 pm Yep welding is a much better idea! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4548 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39049 |
