Browse Forums Renovation + Home Improvement Re: Building a deck - question! 3Jun 12, 2013 2:27 pm It depends on if the deck is built with this in mind. Simple answer is no you couldn't just build a room on top of an existing deck. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Building a deck - question! 5Jun 12, 2013 8:05 pm Actually.. yes you can, if... You have used the appropriate bearers and joists in accordance with the timber framing manual to carry external wall loads. There is absolutely no reason why you couldn't if everything complies. Of course you would need to obtain a building permit before doing so! Re: Building a deck - question! 6Jun 13, 2013 9:01 am That's what I was thinking - yes it's possible as long as you build it with extension in mind. Which will obviously cost more than a regular timber deck.. Thank you for your reply, much appreciated! Something for us to think about. Re: Building a deck - question! 7Jun 13, 2013 12:11 pm Need to get the footings certified for that purpose Landscape Design & Construction http://cherub.squarespace.com/ I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20232 DIY, Home Maintenance & Repair Thanks. I was thinking of using either Extreme Joist or LOWDECK timbers for joists. Any idea what sets them apart and which… 2 12887 I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5720 |
