Browse Forums Renovation + Home Improvement 1 May 16, 2013 3:45 pm HI, I was wondering if anyone could give me some information on the plumbing for an extra bathroom. We have just built a house and want to add an extra bathroom. On the other side of the wall we have the shower and bath from another bathroom. But the only actual thing on that wall pluming wise are the taps for the bath. (hot and cold) I just would like to know what would be the solution to get drainage points can we just pop it through the wall into outside and down so we don't need to affect the concrete slab? Does anyone have a ballpark figure of how much pluming and knocking through walls etc would cost for drainage and plumbing .. $1000 or $10,000? Re: Adding a new bathroom!!!!! no pipes 2May 17, 2013 2:55 pm Without seeing the room and knowing where your plumbing is its like asking how long is a piece of string. You might be lucky and be able to tap into a waste pipe running around the outside of the slab(below ground) If I were you I would ask the company that built your home for the plumbing plans. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Adding a new bathroom!!!!! no pipes 3Nov 29, 2015 8:24 pm Just noticed that it's already an old thread but I got interested in this topic. We're planning to add a small sink in our toilet however I'm not sure how complicated and costly it is to install a new hot and cold water points and water drainage. Thanks Re: Adding a new bathroom!!!!! no pipes 4Nov 30, 2015 1:28 am Just like the OP, you should get quotes from plumbing professionals who are licensed to do regulated work. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 4 5170 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5801 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10937 |
