Browse Forums Renovation + Home Improvement 1 May 13, 2013 1:03 pm Hi all, For our extension (brick veneer house) we will need to remove the bricks on 3 outside walls. What type of tradie and what process would be required for this? Obviously the bricks need to be taken out, and also disposed of somehow. (I guess a skip for the latter). Re: Which tradie to remove bricks? 2May 13, 2013 1:08 pm A brickunlayer.. Seriously, if they are supporting walls, then you need a builder. If they are freestanding then a handyman with a sledgehammer and a skip. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Which tradie to remove bricks? 4May 14, 2013 8:15 am Quote: A brickunlayer Haha, very good Ed. Just make sure if you use a labourer to knock these walls down that they don't do more damage to the existing structure as well. Stewie Unless there were unforeseeable issues with the site, I dont think you should have to pay for contractors errors or poor planning. I'd probably try and be reasonable and… 5 4586 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5992 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11893 |
